2004 525i Sport...Drivers side is one inch lower in the front than pas
My Ride: 530i n52
The drivers side sits one inch lower in the front than the passengers' and the shocks look like they are mounted differently on both sides. And in the back it's the opposite...drivers side is one inch higher than passangers. Take a look at the bolt location and where the arrow is pointing. You can clearly see where drivers side bolts use to be. Pictures are from the front. It looks like the drivers side shock was shifted outwards. The car had alignment done recently at BMW. I have no idea what it was prior to that. Something isn't right?!
Drivers side
Passengers
Drivers side
Passengers
Humm interesting first pic... that doesnt look very promising...
BUT regarding the drivers side being 1" lower... that is normal.
http://forums.e60.net/index.php?showtopic=38202
http://forums.e60.net/index.php?showtopic=29446
http://forums.e60.net/index.php?showtopic=43693
My Ride: 04 545 jet black/beige, smg sport,premium,sunshades,logic7,cwp,nav,pdc,bluetooth,16.0,light tint all around,Pirelli PZeroNero
Something clearly looks wrong -- I'm no expert but it looks as if the centering pin is missing from the first photo (where you have the red arrow).
Take a look at the following .pdf for some information about the components of the spring strut shock absorber assembly:
RA__Layout_of_spring_strut_shock_absorber.pdf
My Ride: May 2008 530D "M" package Exclusive line.
Originally Posted by alexnyc' post='498641' date='Nov 24 2007, 07:08 PM
passenger's side should be lower,not drivers...so i dont know if it's normal...
Ops I dont know what I was smoking when I typed that... even the links confirms passenger side hahah
Brooklyn88
03-21-2015 06:23 PM
