tint and side mirrors
Old Nov 10, 2004 | 07:18 PM
roost's Avatar
My Ride: (Expecting Oct. 2004) 2005 530i Sport package, premium sound package,premium package, xenon's, HUD, sat radio, cold weather package, navagation
I had my windows tinted today with a med. tint and at night I can hardley see out the passanger mirror, is there a way to turn off auto dim on the mirrors
Old Nov 10, 2004 | 07:28 PM
Rudy's Avatar
I don't think it can be turned off except for maybe disconnecting the power or covering the rear-facing sensor on the rear-view mirror.
Old Nov 10, 2004 | 07:40 PM
Iceman's Avatar
My Ride: F02 LCI Individual
Model Year: 2013
[snapback]54829[/snapback]
Or you could put a little piece of tape (what you've cut just the size and shape of the sensor) over the sensor on the rear view mirror.
Old Nov 10, 2004 | 08:15 PM
Rudy's Avatar
[snapback]54834[/snapback]
That's what I was trying to say when I said cover the sensor....
The following might help you figure out how to disconnect the sensor completely. I can't be 100% sure that if you disconnect the wire if you'll still have the rain sensor, garage door opener, and flashing red alarm indicator. Hopefully you'll find discreet wires for each module so that you can keep everything but the dimming circuit energized!
Good luck...
RA__Removing_and_installing_or_replacing_interior_rearview_mirror.pdf
Old Nov 10, 2004 | 09:07 PM
EBMCS03's Avatar
Umm I think hes talking about the passenger mirror... as in the right side mirror not the interior (middle rear view mirror)
Sorry I dont have an answer... All I can say is roll down your windows.
Old Nov 10, 2004 | 09:15 PM
Rudy's Avatar
Originally Posted by EBMCS03' date='Nov 11 2004, 01:07 AM
Umm? I think hes talking about the passenger mirror... as in the right side mirror not the interior (middle rear view mirror)
Sorry I dont have an answer... All I can say is roll down your windows.?
[snapback]54843[/snapback]
The side mirrors are dimmed along with the center mirror. In other words, they all use the same sensors built into the rear-view mirror that I described so by removing wires to the sensor, the outside mirrors should no longer dim (unless, on the other hand, it causes them to dim significantly!)
To verify my theory, the following quote can be found in this document: SBT__Door_mirrors_E60.pdf
Electrochromic door mirrors
Electrochromic door mirrors automatically dim the mirror glass if a source of light from the rear is detected. The electrochromic door mirrors are directly controlled by the electrochromic rear-view mirror. The electrochromic rear-view mirror has 2 sensors that measure incident light from the front and the rear. A voltage signal is output (the strength of which depends on the difference in intensity between the light from the front and the rear) if the light from the rear is more intense. The greater the voltage signal, the more the mirror glass is dimmed.
Old Nov 10, 2004 | 09:31 PM
EBMCS03's Avatar
Originally Posted by Rudy' date='Nov 10 2004, 11:15 PM
The side mirrors are dimmed along with the center mirror.? In other words, they all use the same sensors built into the rear-view mirror
Ah! that makes sense... thanks for the clearification.
Old Nov 10, 2004 | 09:37 PM
Iceman's Avatar
Model Year: 2013
[snapback]54837[/snapback]
I think all the scuba diving is damaging my brain...
Sorry, Rudy. I didn't read your post correctly... Yes, that's what you said...
Old Nov 10, 2004 | 09:41 PM
Rudy's Avatar
Originally Posted by EBMCS03' date='Nov 11 2004, 01:31 AM
Ah! that makes sense... thanks for the clearification.?
[snapback]54850[/snapback]
You got it my friend!
Originally Posted by Iceman' date='Nov 11 2004, 01:37 AM
I think all the scuba diving is damaging my brain...? ?
[snapback]54857[/snapback]
Either the diving or the Mai Tais. It's gotta be one of those...
Old Nov 11, 2004 | 01:17 AM
JDN's Avatar
JDN
roost, that must be a pretty dark tint. I have 36% and haven't noticed the same problem you have, at least I don't think I do. 'Course I have had excellent night vision since an operation a couple of years ago.
