M5 Front Brakes
Old Dec 26, 2006 | 05:37 PM
Rizbel's Avatar
My Ride: 545i Sport
1. Chock rear wheel and lift the front after loosening the wheel bolts.
Remove wheel (ensure 19" rim or bigger for right fit)
I have an OEM M166, so no problem here
Remove 2 Hex bolts to remove caliper housing.
Unscrew inner hex bolt to remove brake disk.
2. Pull out brake pad wear sensor(Present only on left side).
Note: Do not pull the cable, grasp the sensor(green) firmly and pull out.
3. Remove brake line from old caliper housing and install to the M5 caliper housing.
I rotated the housing to prevent hose from getting twisted.
4. Install M5 rotor using single inner hex bolt.
5. Install M5 caliper using 2 hex bolts.
6. Re-install wear sensor
7. Bleed the system. You need another body for this.
Note: Bleed right side then left side.
8. Ensure all bolts are properly torqued then install the wheel, applying proper torque to the wheel bolts.
Next: Brake Fluid Reservoir Access
Rizbel's Avatar
My Ride: 545i Sport
To access the brake fluid reservoir located under the Cabin Air Filter Left housing.
1. Lift(the one I'm pointing at) and slide to the right to remove.
2. Remove filter housing.
3. Rotate CCW.
remove this rubber piece.
4. Lift rubber seal and move aside.
5. Unscrew torx screw.
6. Lift and voila!
Use DOT 4 Brake fluid.
Old Dec 26, 2006 | 06:08 PM
Alex.br's Avatar
My Ride: 2007 E60 M5
Congrats, great job!
Old Dec 26, 2006 | 07:06 PM
quad_m's Avatar
My Ride: BMW 2005 X3 3.0
only 8 steps? amazing.. I am very impressed..
Old Dec 26, 2006 | 07:36 PM
my530i's Avatar
Great! Thank you very very much!
Did you feel brake performance increase dramatically?
Old Dec 26, 2006 | 08:16 PM
Rizbel's Avatar
My Ride: 545i Sport
There is a difference. I want to take it easy for the next 200 miles. A slight vibration that is disappearing as pads wear out evenly.
Old Dec 26, 2006 | 10:31 PM
vegastrashed's Avatar
Way to go Rizbel!
Old Dec 26, 2006 | 10:37 PM
Rizbel's Avatar
My Ride: 545i Sport
My next project:
Any tips/suggestions?
Old Dec 26, 2006 | 10:42 PM
my530i's Avatar
You're now officially mod-addicted
Waiting for another DIY
You might need spring compressor and air wrench to turn spring compressor to compress those springs.
Good luck on your project!
Old Dec 26, 2006 | 11:26 PM
Rizbel's Avatar
My Ride: 545i Sport
Thanks. I'm sorry to say there won't be a DIY. German Werks, an independent German Auto Service and Repair shop in Chula Vista, CA will do the
install.
The steering wheel paddle shifter is still on my wish list though .
