Window Anti-Trap Disabled warning
Old 02-27-2012, 06:25 PM
jaycal3's Avatar
My Ride: 04' 545i, Sport Package, Black, Active Xenon, ARS, Aux Input '10 Tahoe, Black on Black, leather, Nav/XM, 20" tires, full body kit, power 2nd row, loaded '93 Jeep Wrangler, lifted 4.5", 33" meats, Rampage Recovery Bumper w/Tire Swing, etc 25' Aquasport Osprey, Center Console,2012 200 HO Etec
So today I got into my car after work and the stupid chime that I hate so much went on to tell me something other than its cold out... I got a "Window Anti-Trap Function Disabled" warning... So I did what most probably do and shut the car off and restarted... no luck. I tested my windows to see what was going on and found that the drivers side front window would go down automatically but would only come up if I held the button up manually. Normally if I pull the button up all the way and let go the window will come up on its own.
To make a long story short I searched the forums I frequent and found a few differing methods of resetting or initializing the anti trap function... tried a few, while driving and here is the one that worked...
With the window up all the way, hold the button down while lowering the window and continue holding it down for 5 seconds after the window hits bottom. Immediately raise the window by holding the button up all the way for 5 seconds after the window hits the top... Thats it. I was skeptacle but it worked!
Hope this helps.
Old 02-28-2012, 06:10 AM
alooi530i's Avatar
I got the same message before two weeks and tried what you have done and it works.
Old 03-01-2012, 03:43 AM
EvolutionVIII's Avatar
My Ride: 05 545i
I'm pretty sure u have to teach it the stop points. When I did mine I had to go down let it stop. Then go down again like 2 more times then hold it. Don't remember the exact process but it's on here cause that's how I found it. But mine was the rear window. Maybe it's different.
Old 03-01-2012, 04:56 AM
jaycal3's Avatar
No, you dont have to worry about the 2x down thing... like I stated above, this procedure is the exact one I used and it worked.
Old 05-11-2012, 08:01 AM
CDesign's Avatar
Brilliant! Thanks for the tip. Worked great.
Old 05-11-2012, 02:54 PM
604nguyen's Avatar
i have the same issue
Im gonna have to try this today!
Old 05-16-2012, 09:19 AM
604nguyen's Avatar
just thought I'd report back...
This method worked for me...thanks !
Old 05-20-2012, 07:21 PM
AchtungE60's Avatar
My Ride: E60 530i
This is the only method I've ever heard of. One member (i don't remember who! reveal yourself) has like all this on PDFs
Old 07-15-2012, 11:57 AM
Grufnutz's Avatar
I have the same message but window won't go down at all ? It's stuck shut any ideas ?
Old 07-15-2012, 03:47 PM
AchtungE60's Avatar
My Ride: E60 530i
Yes, take the window lock off
Vman33
03-14-2022 04:43 AM
Gadamsm5
E60 M5 Discussion
09-15-2015 11:43 AM
cbdoya
09-15-2015 06:09 AM
bimmerspeed
09-03-2015 09:29 PM
bimmerspeed
Frequently Asked Questions
09-01-2015 05:09 PM
Quick Reply: Window Anti-Trap Disabled warning
