545i low oil pressure warning light
My Ride: Orient blue '05 545i, Sport/Premium Pkg, 6Speed MT, Xenon, Navi, Blue2th, PDC,
I just wanted to share my experience with low oil pressure light in my 2005 545i (106k). It started last night on the way back from work. Lucky for me I was less than a mile away from home when it started. It was pretty random ? engine was running just fine and the light was coming on and off at high rpms and while idling.
Today I took out oil pressure switch and I discovered that it was leaking from inside. Oil was getting inside the plug and wire harness causing a short.
$12 + an hour later I have a new switch. I hope that will fix my problem - test drive tomorrow. Will keep you updated.
That is great. Where is switch located on the engine? Just in case I start having this issue.
My Ride: 04' 545i, Sport Package, Black, Active Xenon, ARS, Aux Input
'10 Tahoe, Black on Black, leather, Nav/XM, 20" tires, full body kit, power 2nd row, loaded
'93 Jeep Wrangler, lifted 4.5", 33" meats, Rampage Recovery Bumper w/Tire Swing, etc
25' Aquasport Osprey, Center Console,2012 200 HO Etec
Under the vacuum pump(just left of center looking at the engine, down about half way.)... I found if you remove or temporarily relocate the coolant expansion tank, you can get your hand in there without removing anything else.
dv8ed
Dec 24, 2003 07:41 PM
