E60 Strut mount/bearing replacement
Hey guys, will I finally figured out why my car was shacking on the freeway and making horrible grinding noises when turning. I started to suspect strut mounts/bearing after the same thing happened to my E38. The nice thing about the strut mounts on the E60 is that the bearings can be inspected just by opening the hood and removing the plastic cap at the top of the strut mount. I had several other issues to deal with at the same time, its unnecessary to take things this far apart. I thought I would share just so you could see how worn the bearing were after 150K miles.
DAMN YOU Harbor Freight!! Can't even make a decent spring compressor!!
My Ride: 2008 535i steptronic\jb4with fsb \bms dci\meth\AR cattless downpipes \3inch dual mandrel bent exhaust with quad tips\bms 15mm spacers with vmr 710 19'' rims blacked out\\with many cosmetic mods also\ car is blacked out!!!!soon to have quaife lsd
What were the torque specs everything I just did the same evryhting today and now have a very heavy clunk noise over bumps please help
I had the same issue...after much checking look at the top of the shock piston where it sits into the bottom of the strut mount/bearing, I saw that it wasn't drawn all the way up. Remove the cap at the top of the strut, use a 21mm socket and tighten until that gap closes up...its a conical piece that had to be pulled tightly into the mount...phew, car drives like a dream now after a week of that annoying thud...good luck
socale39
09-05-2023 08:30 AM
