right led eyebrow is not working
My Ride: BMW 525 E60
Hello !
Recently I had a moisture in my right Led eyebrow and it worked just fine, but I had a stupid idea to get the moisture out by taking the headlight out and puting it in a warm place (near the radiator) I waited for about 4 days and nothing changed so I decided to put my headlight back. Now my headlights right eyebrow is not working proper, only 2 leadlights is now working on that right eyebrow and is not as bright as before. Left side is working just fine but the right side eyebrow is having problems.
So I would like to ask for a suggestions! What should I do? Is there any fuse I need to change? Is there any wire or any other method to fix this?
My Ride: Bmw 530d 2004
I have the same problem with my left eyebrow. Occasionally it works fine though...
There's no fuse for that, because it's probably a contact problem. A true fix would be cutting the eyebrow section open and change the leds, but it isn't very easy job to perform.
Try the following at first:
1) Unplug the eyebrow cable
2) Attach some kind of an adjustable power supply to the eyebrow plug
3) At first give the eyebrows approx. 16-17 volts, they should lighten up
4) Then turn the voltage down to 13-14, they should stay on
5) Leave the power supply attached for hours, or days
This helps me to get the eyebrows work properly for months usually. Sometimes I have to repeat the procedure. Haven't got enough courage to cut the headlight open and properly fix them.
- Antti -
- Antti -
- Antti -
- Antti -
Will it charge with only 12V, I just can't find power supply with 17V !? Maybe you could suggest witch power supply to use?
milhouse4u
04-22-2015 04:43 PM
