Sunroof wind noise - fixed
Old 07-12-2011, 12:41 PM
stulios's Avatar
Hi all
Bought myself a new panoramic sunroof seal from BMW the other day (£20)
Took about 1 hr to strip the old seal off and clean all the "sticky" stuff off...
..and about 20 mins to fit the new one! Then initialised the sunroof by holding the tilt button down for a short while.
A very easy job...and what a difference! I haven't had the screen closed since and even on the motorway (70mph...ish) there is little if any wind noise.
Highly recommended for anyone suffering from excessive wind noise when running at 30mph+
Here's a pic of new on the left and old on the right for comparison.
Stu
Old 07-12-2011, 07:26 PM
vash68's Avatar
My Ride: 2009 535xiT Silver/Gray with Sport, Nav, Cold, Convenience, Logic7 and more.
Does it go around a glass or a roof opening and how is it attached?
Old 07-12-2011, 10:05 PM
Lotus99's Avatar
My Ride: 2010 535 xi - M Sport Pkg & other goodies
Nicely done. Yeah, a pic of it installed would be great to have an idea.
Old 07-12-2011, 10:08 PM
neil.d's Avatar
And the part number would be helpful if u could, thanks.
Old 07-12-2011, 10:44 PM
Lotus99's Avatar
Is this the tech bulletin on what you did?
Old 07-12-2011, 11:43 PM
stulios's Avatar
Hi
Yes, that's the same issue i was faced with, and the same part number I bought: 54 10 7 199 533.
The seal goes around the roof, not the glass and come with a sticky backing ready for installation. The pics below show the roof closed (The new seal is on the right)and the roof slightly open. I've also put one up of the bag the seal came in, in case it helps!
Stu
Old 07-13-2011, 09:00 AM
Lotus99's Avatar
Good to hear, the SIB says only those produced up to 11/2008 are affected, which means some of us hopefully won't have to do this!
Old 07-13-2011, 10:58 AM
neil.d's Avatar
Nice one, thanks a lot for the info.
Old 07-13-2011, 11:37 AM
vash68's Avatar
Lotus, where do you download BMW TSBs?
Old 07-13-2011, 12:14 PM
Lotus99's Avatar
It's top secret!
They actually used to be publicly available - if you knew the web address - but I think BMW caught on too many people were reading them and going into dealers with info the dealer was supposed to know, but didn't , so they locked them up! Now, I just grab them when I see them posted as attachments. Guess people with connections still manage to get them somehow.
They used to be like this:
Code:
http://www.bmwtis.com/tsb/bulletins/bulletin_graphic_temp/B131310g.htm
So if you knew the SIB number, you could just type it in the path, and get it.
Quick Reply: Sunroof wind noise - fixed
