♦ Sonic MS | StopTech Performance Braking Product Line
![](http://img534.imageshack.us/img534/9408/smsax.png)
Sonic Motorsports
1045 West El Camino Real
Mountain View, CA 94040
tel: 650-733-6506
fax: 650-691-9009
email: info@sonicms.net
tel: 650-733-6506
fax: 650-691-9009
We at Sonic MS are proud to present StopTech's line of Performance Braking Products for your E60.
All prices listed do not include shipping and/or tax if applicable.
For ordering information, please contact me at 650.733.6506, email at cal@sonicms.net, or shoot me a PM.
StopTech "SportStop / PowerSlot" Replacement Rotors
StopTech (AKA Centric) rotors are identical in dimensions and internal vane design to the factory originals. During assembly, rotors are straddle cut for the most accurate machining, then double disc ground for optimum parallelism, minimal runout, and near zero thickness variation. A non-directional finish is applied for better initial pad bedding.
![](https://img193.imageshack.us/img193/2200/stopteche92rotor.jpg)
![](https://img502.imageshack.us/img502/8564/centri1.jpg)
All surfaces, including the hat, are machined and non-swept surfaces are electrostatically coated with a durable, black finish for corrosion protection and good looks. Finally, all rotors are computer mill balanced to incredibly tight tolerances. Available in slotted and/or cross drilled varieties. Blank replacements also available upon request, contact me directly for more info.
Pricing
E60 525i/530i
Front
Slotted - $290 /pair
Drilled - $310 / pair
Slotted & Drilled - $325 / pair
Rear
Slotted - $250 / pair
Drilled - $250 / pair
Slotted & Drilled - $270 / pair
E60 535i/545i/550i
Front
Slotted - $300 / pair
Drilled - $320 / pair
Slotted & Drilled - $335 / pair
Rear
Slotted - $275 / pair
Drilled - $275 / pair
Slotted & Drilled - $290 / pair
StopTech Stainless Steel Braided Brake Lines
Improve pedal feel by replacing stock rubber lines with StopTech stainless steel braided Teflon® lines. Stock lines expand under pressure, contributing to spongy pedal feel. StopTech lines reduce pedal travel and firm up pedal feel, allowing precise brake modulation. Useful for drivers who "heel-toe" downshift, providing a more stable platform from which to modulate the throttle to match engine revs to transmission speed.
![](https://img16.imageshack.us/img16/9301/stoptechbrakelines.jpg)
StopTech lines are covered with stainless steel weave to provide support and protect from abrasion and impact. The stainless braid is molded inside a layer of clear plastic to protect the lines from the environment and to protect your car's suspension and delicate sensor wires from the "hacksaw effect" possible with uncoated steel braided brake lines. These lines are DOT compliant and may be legally used on the highway, unlike lines sold for "off-road use only." StopTech lines have been tested and approved by the TÜV for sale in Germany.
Every StopTech line is tested at 4,500 psi before it is packed and shipped. Most manufacturers perform no pressure testing. Some test random samples from their assembly line or test to lower pressures. No other company tests every single brake line.
Applications:
All E60 525i / 530i / 545i / 550i / M5
Pricing
Front (MFG PN 950.34011) - $75
Rear (MFG PN 950.34522) - $69.99
StopTech Street Performance Brake Pads
StopTech Street Performance brake pads are StopTech's newest formulation, offering an unusual combination of good bite, low noise, and extremely wide temperature range, making them ideal as "dual use" street to medium track pads. These are the standard pads included with StopTech big brakes and are now available for many OEM applications.
![](https://img838.imageshack.us/img838/6596/stsport.jpg)
Applications
- E60 535i/545i/550i
- E60 M5
Pricing
E60 535i/545i/550i
Front (MFG PN 63-309-0918) - $110
Rear (MFG PN 63-309-0919) - $90
E60 M5
Front (MFG PN 63-309-1151) - $195
UltimatePeter
DIY: Do It Yourself
09-28-2015 09:12 AM
TexaZ3
05-06-2015 09:54 AM
carid
03-06-2015 04:58 AM
