Need help identifying bulb/connection type
Old 02-07-2011, 04:48 AM
Cartmanizm's Avatar
My Ride: BMW 530i
Engine: N52N
Hey guys,
Got my new toy the other week, a 07 530i 200kW. I'm going through and replacing the different stock globes to a whiter light but I've hit a bit of a problem. In the car manual it says that the daytime running lights uses a H8 globe. So I went out and purchased a pair (costed me $100), the Philips Blue Vision H8 (which are the whitest ones which are legal in Australia). Took out the bulb housing and discovered that the H8 globes don't fit!
Here is the globe which I found inside:
The connection that it came with to connect the globe to the power source:
Can somebody help me identify what I would need to get to replace these? The manual says H8 but these aren't H8 stock globes! Or what adapter can be used to make the H8 ones connect?
Old 02-07-2011, 05:49 AM
luigi524td's Avatar
If this is your first BMW ... you learned a valuable (but expensive ) lesson. "Don't trust any guides that tell you the type of bulbs in your car!" ... remove and inspect to confirm type FIRST.
Mid-production changes are often made. Besides, the inboard lamps (if that is what your are calling your DRLs) for both halogen and xenon are H-7's according to
http://www.sylvania....LRG-Results.htm
Where did you say the advice that they were H-8's came from - your owner's manual ?!?!
Old 02-07-2011, 08:07 AM
E92-Lighting's Avatar
My Ride: Next Gen LEDS
H8 is only for xenon models of LCI E60's
Old 02-16-2011, 08:47 PM
Cartmanizm's Avatar
My Ride: BMW 530i
Engine: N52N
Sorry for the late reply. The guide was from the owner's manual :S. Anyway I was able to return the bulbs so it's all good.
The bulb in the daytime running lights (that powers the angel lights shown below) were the crappy little halogen one, how is a H7 meant to plug in?
H7's have these connections:
Doesn't fit these:
Or is there some adapter that I can buy to make them fit?
Old 02-16-2011, 09:20 PM
turboawd's Avatar
My Ride: 2006 BMW 550i
you cant just buy a replacement bulb. you either get the oem replacement or go with an aftermarket like the mtec bulbs, etc.
Old 02-16-2011, 11:14 PM
Cartmanizm's Avatar
My Ride: BMW 530i
Engine: N52N
Hmm ok. What is one that will match the Philips Bluevision (4000k)? Bluevision is the whitest roadlegal light to have in Australia so yeah.
Old 02-17-2011, 12:38 AM
Cartmanizm's Avatar
My Ride: BMW 530i
Engine: N52N
Btw my car is a LCI model (non xenon)
Old 02-20-2011, 05:58 AM
Cartmanizm's Avatar
My Ride: BMW 530i
Engine: N52N
bump?
Stuboski
11-05-2021 06:58 AM
umichchris
12-10-2015 01:00 PM
Kaane
09-26-2015 07:44 PM
knklhead
08-20-2015 08:40 PM
jimmychef
07-07-2015 05:17 PM
Quick Reply: Need help identifying bulb/connection type
