NCSExpert Code Mods
Old 12-22-2010, 09:29 AM
NoQuarter's Avatar
Use this thread for specific code testing results with NCSExpert
For information on how to do this search for other threads for NCS, NCSExpert, INPA, Car Coding, etc.
* If you are not already making code changes then read but don't post!
* There are lots of threads or create a new one for questions on how to get started, where to find cables, software, etc.
* This thread is for people already coding and testing only
Try to stick with ones you have validated that works or even ones you tried that didn't work.
CAPPL:
LEGAL_DISCL (No legal notice on IDrive startup)
nicht_aktiv
VA_WELCOMELIGHT (Welcome lights menu in iDrive. Requires change in LMA module also)
aktiv
ONLINE (Enables BMW Onine in Communications iDrive screen- Works in UK? not in USA?)
aktiv
SIM (Activate SIM for internet svc - no "GSM" service message for USA)
aktiv
VA_CORNERINGLIGHT (Cornering lights menu. Lights come at low speed turns, with turn signals and in reverse.)
aktiv
VA_SEATCLIMA_SHORTCUT (Seat heater display comes up in iDrive when heat button pushed)
aktiv
VA_SEATHEAT_SLIDER (Seat heat hi-med-low slider in iDrive)
aktiv
VA_LONGDISTANCELIGHT (Shows Highbeam assistant menu option. (must have the hardware too for it to do anything)
aktiv
VA_ADAPTIVEHEADLIGHT (Adaptive headligh menu with Comfort and Sport options. Doesn't seem to do anything with any of the settings)
aktiv
LMA:
WELCOME_LIGHT_Active (Welcome lights menu in iDrive. Requires light switch in auto position)
aktiv
WL_DAUER (Does this make welcome lights stay on longer ?? )
wert_02
WL_NSW (Fog lamps with Welcome lights)
soft_einschalten
FL_UND_NSW_NICHT_GLEICHZ (Allow High beam and fog lamps on at same time)
active
BI_XENON_BEI_LH (activates your Bi Xenons flash to pass feature) works on the PRE-LCI also
aktiv (* This worked for d4rkchocolate but not for NoQuarter)
KOMBI:
BC_DIGITAL_V (digital speedometer is cluster)
aktiv
SHD:
REGENSCHLIESSEN (close sunroof with auto wipers and rain. Anyone know how to test this? doesn't work for NoQuarter)
aktiv
CAS:
KOMFORTSCHLIESSUNG_FB (Close windows via key FO
aktiv
IHKA:
GEBL_ANZEIGE_AUTO (Climate fan speed display via orange light around manual speed knob)
active
HUD:
BLINKER_AUSSTATTUNG (turn signals in HUD)
aktiv
Old 12-22-2010, 09:34 AM
NoQuarter's Avatar
Blood... I know you have some mirror options but I wasn't sure what module to put them in.
Old 12-22-2010, 02:04 PM
BLooD's Avatar
Noquarter the IHKA one only works on the IHKA high, will not function on my basic IHKA.
KGM (sept 2005 onwards)
BEIKLAPPEN_B_KOMFORTSCHL Comfort folding mirrors (Needs SA430)
ASP_BORDSTEIN Passenger mirror kerb function (Needs SA430)
CAPPL
ONLINE_DISABLE_CONTENT Enable BMW online while driving.
(set to content_enable)
VIDEO_DENY_COB Enable video functions while driving
(set to deny_never)
TCU
RINGTONE Changes incoming call ringtone
(3 settings)
Old 12-23-2010, 04:33 AM
BLooD's Avatar
CAPPL
ACOUSTIK Sets alarm sound function when locking/unlocking
Old 12-23-2010, 05:02 AM
NoQuarter's Avatar
updated...
CAPPL:
nicht_aktiv
aktiv
aktiv
aktiv
(set to deny_never)
aktiv
aktiv
aktiv
aktiv
aktiv
LMA:
aktiv
wert_02
soft_einschalten
active
KOMBI:
aktiv
SHD:
aktiv
CAS:
aktiv
IHKA:
active
HUD:
aktiv
ASP_BORDSTEIN Passenger mirror kerb function (Needs SA4)
TCU
(3 settings)
Old 01-02-2011, 01:55 AM
Ehssan's Avatar
My Ride: Many BMW's
I can't wait for my cable to arrive ,, I want to try few things
Old 01-02-2011, 07:50 AM
NoQuarter's Avatar
updated...
CAPPL:
nicht_aktiv
aktiv
aktiv
aktiv
(set to deny_never)
aktiv
aktiv
aktiv
aktiv
aktiv
LMA:
aktiv
wert_02
soft_einschalten
active
KOMBI:
aktiv
BEIKLAPPEN_B_KOMFORTSCHL Comfort folding mirrors (Needs SA430 if you are retrofitting folding mirrors)
SHD:
aktiv
CAS:
aktiv
IHKA:
active
HUD:
aktiv
TCU
(3 settings)
Old 01-06-2011, 03:17 AM
larry_bml's Avatar
Someone knows how can i do WELCOME LIGHTS to an e90 ? I just did WELCOME LIGHTS in iDrive menu, but it doesn't work. It can be selected but it will shortly deselected itself. Please help.
Old 01-06-2011, 03:19 AM
BLooD's Avatar
have you read any of this thread?
Old 01-09-2011, 10:24 PM
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
Blood: since you're one of the more experienced guys with coding on here, do you know why I don't have the CAPPL module? I load up CAS and LMA (to check) and I don't have it
That being the case, the iDrive warning sign active/inactive can be located somewhere else?
Quick Reply: NCSExpert Code Mods
