DIY: Rear Sway Bar
Tools you'll need:
16mm wrench
T30 torx head socket I used 1/4 inch drive ratchet
3/8 drive ratchet
3/8 socket 14mm
14mm wrench
Grease
spare jack stand (optional)
Jack the car up and support it with stands or use Rhino Ramps. I used Rhino ramps so. Be safe though.
One car is up, you wanna loosen the endlinks first using the closed end of the 16mm wrench over the nut, then take the T30 torx head and hold the bolt from spinning, then ratchet the nut off the bolt, do that on both sides. Next take your 14mm socket and break loose the nut on all 4 bushing brackets, then take your 14mm wrench and feed thru to the top of the bolts holding the brackets on and once in place ratchet the nut off the bolts. Now you will take the bolts out from the top, Caution that the bar might fall once all nuts are taken off in this case use a spare jack stand and place it underneath the sway bar. Mine was seized in place so it didnt fall but you never know. A few tuggs may be needed to remove.
Once off, look at the location off the stock mounts. The new sway bar will come with bushings so take the grease and apply a liberal amount and wipe some inside the bushing and then put a little on the sway bar where bushing will sit. It will take some finessing to get the new bushings on the bar, slide the bushing close to wear stock is then push straps over the bushing after that reverse the install. I am sure I missed something so please ask
![](https://i47.photobucket.com/albums/f152/myfotosspot/2010-08-12180522.jpg)
![](https://i47.photobucket.com/albums/f152/myfotosspot/2010-08-12180515.jpg)
You can see stock vs Dinan 21mm!!!
![](https://i47.photobucket.com/albums/f152/myfotosspot/2010-08-12180539.jpg)
16mm wrench
3/8 drive ratchet
3/8 socket 14mm
14mm wrench
Grease
![](https://i47.photobucket.com/albums/f152/myfotosspot/2010-08-12180510.jpg)
My Ride: E60
Great job posting the DIY!
This is an easy DIY mod with a definite performance improvement thats quite frankly overlooked.
I swapped out my front and rear sway bars for the M6 convertible bars.
29mm in the front
20mm in the rear
29mm in the front
20mm in the rear
I replaced front and rear sway bars 2 weeks ago and the difference is so amazing. Its a great mod if you love turning sharp or changing lanes like you're in a go kart!
![Worthy](https://5series.net/forums/images/smilies/imported/worthy.gif)
My Ride: Sapphire Black 07 530i non-sport
7000k Angel Eyes
6000k HID Xenon adaptive turn Head lamps and Fogs, Clear LED Turn Signals front/back and side markers. Clear bright license plate lamp. Full interior lighting upgrade.
Coding: daytime angel eyes, auto windows up, and digital speedometer. (Thanks to John at Motorcepts.com)
OEM Tinted LCI Tail lights (Thanks to David at http://www.luxmotorwerks.com
Oem Mtec rear bumper with diffuser and M5trunk finisher
Debadged! The best paint work! (Thanks to Desimone BMW)
20x8.5 +18 20x10 +25 Concept One RS-8 Black Machined Chrome Lip
V6.1 cables (Thanks to Bruce Miranda)
Nitto Invo tires 285x30 R20 - 245x35 R20
Discounttire.com
Vac Motorsports ecu chip upgrade, and fender roll
http://vacmotorsports.com/
wish list:
Rieger Front bumper
Hamann side skirts
Custom quad exhaust
Rpi Ram air intake scoop
M5 SMG shift knob
KW Variant 3 suspension
Brembo Big Brake kit
LCI Heads
Tints
BMW M5
What brand makes the best sway bars?
