BMW DCT Shifter Retrofit Kit
We were the first to introduce the E60 and E63 harness and are proud to now introduce the harness for all common BMWs such as the 1, 3, 5 and 6-Series. More models are to come... if you don't see it available, contact me and I'll make one for your specific model.
This German engineered Kit will permit you to replace your current Steptronic shifter with an illuminated DCT shifter while being completely Plug N Play. In addition, the Kit is made to perfectly conform and fit under your shifter base plate without any excess wires that can get in the way.
Shifter Options:
M3 Shifter: This shifter illuminates R, N, D, DS as well as the + and - on the shifter when shifting up or down in DS mode!
M5/M6 Shifter: This shifter illuminates R, N and DS. Now illuminates DS on the shifter in both D and DS mode!
DCT Shifter: This shifter illuminates P, R, N, D and DS!
Install Time: Approximately 10-15 Minutes
Shifter Options:
TroyE60
05-30-2019 05:01 PM
jwdominick
05-19-2015 02:50 PM
