5Series.net - Forums
-   Tires & Wheels (https://5series.net/forums/tires-wheels-52/)
-   -   Will these fit? (https://5series.net/forums/tires-wheels-52/will-these-fit-135887/)
540i 11-14-2013 11:30 AM
Will these fit?
I've been doing a lot of research but haven't been able to find an answer.
I've been searching for a nice set of winter wheels and tires and I found some, but I'm not sure if I will need to replace the tires or not.
I checked the rear stats and I don't think I should have a problem with the rears. i think the front might be an issue. Right now I have Style 95s from a 7 series in the front (19x9 - 245/35/19) and when i got these, I had to switch from 245/40s to 245/35s due to rubbing against the suspension, which is my main concern with the set I'm trying to get.
The set I'm trying to get are mounted on style 61 wheels from an E38. The Style 95s had an offset of et 24 and the E38 set have an offset of et 20. The wheel is narrower (16x7.5) but it has a much bigger sidewall. The tire size are 245/60/16 all around.
Taking everything into account, will I have rubbing issues again and will I have to replace the front tires?
