Will 7 Series wheels fit?
Old 06-15-2010, 03:45 PM
andy530i's Avatar
Default Will 7 Series wheels fit?
I'm looking at some 7 series wheels on e-bay and wondering if they will fit my 530 and look good too! They are style 149's 20x9 (F) 20x10 (R). Offset is 24; bolt pattern is 5x120. I am looking at these 20's because they will work with my current tires... just want to make sure the rim fits the car.
Thanks!
Old 06-16-2010, 06:29 AM
tooltec's Avatar
My Ride: 2007 530d M Sport Automatic, Le Mans Edition.Le Mans Blue Individual Paint Special, Syrah Blue Individual Leather, Piano Black Individual Interior Trim, Front seat heating,M Double Spoke 172 19
Alpina 20" alloys,8.5" front,9.5"rear,have offsets 20mm and 24 mm respectively.Therefore the rear is o.k.Hartge 9"x20" front have an offset of 18mm therefore you need confirmation from others that the front would fit.It also depends on your tyre sizes of course.
Old 06-16-2010, 09:10 AM
andy530i's Avatar
Thanks, I suspected that the rear wheels would be fine. I guess I'll wait to see what everyone else says about the front wheels.
Old 06-16-2010, 09:31 AM
PraiseTheLowered's Avatar
im running 20x9.5 et16 and the wheels fit without spacers and full drop but i had to run a slightly smaller tire to makre sure it wouldnt hit the strut
Old 06-16-2010, 09:32 AM
TakmaN's Avatar
My Ride: 2005 BMW 545i
The front and rears have +24 offset?
If so, those wheels will fit fine. The only issue you might have (which I 99% doubt) is the front wheels hitting the inner struts. You might want to put on a 5mm spacer in the front to make it more flush though. And I would recommend running the following size tires: 245/35/20 F and 275/30/20 R if you have crappy roads or 245/30/20 F 285/25/20 R if you have awesomely awesome roads.
Old 06-16-2010, 01:07 PM
530D Lee's Avatar
My Ride: BMW
My E60 runs on style 95 (7 series alloys) 9jx19 Front and 10jx19 Rear, with +24mm offset and 245/35/19 and 275/30/19 respectively with no scrubbing or any other issues, also lowered on Eibachs. I cant see any problems with the wheels you are showing.
Old 06-16-2010, 03:23 PM
andy530i's Avatar
Thanks everyone for the advice! I'll keep you updated on which direction I go.
Old 06-17-2010, 01:25 AM
Dav530d's Avatar
Yes they will fit. I'm running style 101 with et24 all round. No issues
Old 06-17-2010, 02:15 AM
xBMWx's Avatar
As the others confirmed, the wheels will fit, its the tyre size that is key in all of this -- see above.
Here is a pic of an E60 with the standard 7er tyres, so as you can see, the wheels look great but the tyres need to have slightly smaller walls (- I believe these 7er tyres are 245/40/20 and 285/35/20). The sizes TakmaN listed above look right to me. More details on that car here. Good luck with the purchase
Old 06-17-2010, 12:41 PM
andy530i's Avatar
Thanks again everyone! I bought the wheels and they should be shipped out today!! I'll post pics when they are mounted.
Quick Reply: Will 7 Series wheels fit?
