wil they fit?wheels
i have a question...
i m looking to buy 8,5x20 ET37 fronts : 10,0x20 ET35 rears http://www.njuskalo.hr/image-w920x69...a-57057186.jpg will they fit on e60 2006 535d and if they will what tires to use? i m lowered on ap coils and i want to go slight lower on 20" car in question https://scontent-vie1-1.xx.fbcdn.net...f2&oe=570A26D9 |
AFAIK based on the wheel specs the offset number is too big for your car spec.
Usually big/high offset number is for xi/AWD model while RWD car uses small/low offset nbr.
Originally Posted by Mexx535d
(Post 1572827)
i m looking to buy 8,5x20 ET37 fronts : 10,0x20 ET35 rears will they fit on e60 2006 535d and if they will what tires to use? i m lowered on ap coils and i want to go slight lower on 20" car in question |
You would need massive spacers. 20+mm to fit them. I would skip.
what is ideal offset an rim wifths on e60?
this will fit?
Front: 9,5x19 ET22 235/35/R19 - REAR: 11x19 ET25 265/30/R19 |
