widest rear tire on oem m5 wheel
Hi! Currently i Have 285/30/19 size tire mounted on the rear wheel. Wheel is oem m5. Car is 2006 530i sport. Can i go wider with 295/30/19 on the rear without rubbing? Im not planning to lower my car or do any suspension upgrade. What is the widest i can go with? Thanks again.
i have 295/30/19 on M5 wheels,it does rubbing on arches when you have some1 on the back seats,another wise all good :) but i would keep 285 to be honest.... hope it helps;)
I have 285/30/19 rims 19x11 offset 25 no rub at all oh with 3mm spacer.
recommended for a non-M on that 19x9.5 166 wheel is 275/30/19. some do go with the bulkier 285 width but I wouldnt recommend going wider than that.
