why do ome size front m5 tires dont fit other e60s?
i found a nice m5 set of wheels to put on my non-sport 530i.
Have been doing some research, and apparently the stock 255-40-19 m5 tires rub on other e60 models?
can anyone confirm this? i dont understand why it would work on an m5 and dont on a regular e60
thanks for your time
e60 m5 fenders are flared out, allowing for a wider tire and wheel along with lower offset...
5Series.net - Forums - Gene's Album: AW LCI 535i
e60 specs are in my sig..
try using the tire/rim calculator the forum provides. Upper Nav bar, under "Tools"
My Ride: BMW E60 M5
Model Year: 2010
Engine: S85
The short answer: Yes, you can "get away with it", but it WILL rub. The tire is simply too wide for non-M cars. The choices are: cut the inner fender wells to fit the new tires, or get an new set of front tires, and lastly buy M5 fenders and fender liners to fit M5 tires on your car (option 2 is the least costly and requires no changes to your car itself)
My Ride: Bmw 530d 2004
- Antti -
BrandonSS
03-13-2015 12:19 PM
