Valve caps
Old 01-06-2019, 12:37 AM
andy007's Avatar
Default Valve caps
Don't buy cheap as chips fancy Chinese tyre valve caps without putting some sort of grease on them before fitting them as I did. They were on for 8 months and wouldn't unscrew, they stuck fast, tried with mole grips etc, valves snapped off, two went, dohhhhhhhhhh
Old 01-06-2019, 07:44 AM
Administrator
JayArras's Avatar
My Ride: 530xi
Engine: N52
Good advice. Thanks, Andy!
Old 01-06-2019, 08:08 AM
FormerE30Owner's Avatar
My Ride: 2005 545i, premium package, 6sp manual, cold package, navigation package.
Model Year: 2005
Engine: N62
Not a problem if one checks tire pressure at least once a month!.
Old 01-06-2019, 11:53 PM
andy007's Avatar
Because it has the flat tyre monitor, they rarely need checking.
Old 01-07-2019, 06:15 AM
Administrator
JayArras's Avatar
My Ride: 530xi
Engine: N52
It's a good practice to do so however, to prolong the life of your tires and improve gas mileage.
Old 01-15-2019, 02:47 AM
andy007's Avatar
my tyres last about 1 year, all brands wear out so much, only do about 15,000 on them, terrible
Old 01-15-2019, 05:44 AM
Model Year: 2005
Engine: N62
Maybe its because you don't check the tyre pressure often enough and they end up low, with the attendant premature wear. The harder you are on the tyres (very sporting driving etc.) the more the tyres will lose pressure, therefore the more you need to monitor them physically yourself. The flat tyre monitor will not tell you if all the tyres are low pressure, only if one tyre is much lower than the others.
Old 01-24-2019, 09:36 AM
andy007's Avatar
brendinernst
12-01-2013 04:26 AM
craigt-from-atl
04-16-2013 01:21 PM
TX Buzzard
03-29-2008 05:16 AM
titanic
07-19-2007 08:26 PM
555
15
06-04-2005 05:01 PM
Quick Reply: Valve caps
