Tires help
Okay I know there isnanton of topics about this. But I have an 07 530i and I just got a set of 166 staggard 19's I need help with tire size for the front and rear. I want the nice aggressive look
But not rolling fenders or rubbing. Just want a clean aggressive look. And will I need spacers to give me that look? Thanks
275/30 Rear
12-15 mm Spacers on rear (assuming you have the M5 ET28 Rear Size alloys.
Okay thanks so far that's the size I been getting. Now when you say M5 Et28 do you mean that they are genuine factory wheels? If so yes They are. Thanks
I am running 245/35/19's up front and 295/30/19's out back. No rub at all and oh so fat in the back. Looks nice.I could do a 5-8mm spacer in the back, but just haven't wanted to mess with really.
If yours are factory M5 version then they will be et28 rear which needs 12-15mm spacers to look great with 275/30 tyres which is the recommended size for Non-M5 Staggered.
The 166's in the factory M6 version have a rear et17.
My Ride: 2008 535i
epilithic@gmail.com
Can you post or send me a pic of your rear tires? I want that 'oh so fat' look in the rear as well. Currently i am running 275/30/19 with h&r lowering springs and there is so much gap. Im thinking either 275/35/19 or 295/30/19 will help fill it out nicely.
epilithic@gmail.com
epilithic@gmail.com
My Ride: 2008 535i
looks siick! Unfortunately i wont be able to use 285/35, i have h&r lowering springs. i might be able to get away with 285/30 though.
