Tire Fitment
Old 04-19-2013, 01:38 PM
JerimiahLee's Avatar
Will I need hubcentric rings?
Old 04-19-2013, 03:01 PM
in your original post you mentioned the bore size is 72 for those wheels, so no you will not need hub rings.
Old 04-24-2013, 07:22 AM
Ok great. Thanks for all the help so far. The wheels I originally wanted do not come in matte or gloss black so I am back to the drawing board. I am two new potentials and have included links as well.
These are the alternatives. Will these specs as well make a difference in the tires I order? Only difference is the offset is higher.
Specifications:
Size: 19x8.5 Front / 19x9.5 Rear
Bolt Pattern: 5x120
Finish: Matte Black
Offset: ET40 Front / ET40 Rear
Hubcentric: 72.6
http://www.oemwheelsplus.com/bmw/19-...heels-set.html
As well as these, these are obviously 20 inch wheel, will they fit well? I am not lowered at this time. And what is a good suggested tire size? They also have them in 19's.
Front Size 20x8.5
Offset 35
Rear Size 20x9.5
Offset ET 37
Bolt Pattern 5x120
Hub Bore 72.56
http://www.ebay.com/itm/20-BMW-M5-St...item43ba4568b6
Old 05-19-2013, 03:50 PM
David Mai's Avatar
Hi, I just bought some new wheels 19 (6 series style rims) and bought tire for my 06 525i. I took it to Sears to install the tires i got from them. They say the 245/35r/19 will not fit the rims due to the rim size. So I had to go down to 235/35R/19 front and 245/35R/19 rear? What size whould I have put for fron and rear for my style rims?
Old 05-19-2013, 05:34 PM
BlaSTiWi's Avatar
BMW recommended 245/35-19 front & 275/30-19 rear ... some member(s) go 285/30-19 rear.
Old 05-29-2013, 06:06 AM
sedoy's Avatar
You don't know which wheels he got, what if he got 4x 19x8.5 replicas... good luck with 285/30 on 8.5" wheel...
275/30 recommented for the 9.5" wheel width.
Nihilation
07-10-2022 11:32 AM
TroyE60
03-05-2016 09:03 AM
carid
05-27-2015 11:34 PM
Stunin5
05-10-2015 07:38 PM
Gizmo
Lounge
07-16-2004 05:15 PM
Quick Reply: Tire Fitment
