1 Attachment(s)
I have OEM 166's installed with m6 offsets in the rear with stock sports suspension. I had the in laws in the back seat on Sunday and noticed on certain dips, the rears rubbed. Debating if I should roll the rear fenders. What would be the best solution to stop rubbing when you have people in the back seat?
i recently went through with the same problem so i got my rears rolled but im still rubbing on big dips and with passengers in the back.
im really considering getting my camber more pushed in. GL with your search! |
smaller tires for easy fix.... coilovers if your gonna be modding more
try adding more air pressure when having people
Had the same thing except my parents were in the back, ima get the rears rolled soon
Get your fenders rolled and lining shaved. Call Tony Saggu 818-368-4395. He has done several members on this forum. You will leave satisfied and be able to have a full car of people and not rub. Trust me it is worth the drive. He hooked me up big time.
Originally Posted by SD5Series
(Post 1442453)
Originally Posted by Persuader
(Post 1442903)
What size tyres do you have. 19" M5 size or Regular 19" size. If the former then that will explain the rubbing.
I think you should roll your fenders. It will only get worse if you eventually get 20"s and the recommended tire size diameter is about 1" bigger (275/30/20) than 19" (275/30/19).
i took my car out for the first time with a full load. 2 up front 3 in the back. never again.
