recommended spacer for oem 166
My Ride: coilvers retrofits
Model Year: 2001 and 2011
i finally got some oem 166 wheels and while i believe the best tire size for my e60 on h&r springs would be 245-35-19, as i really would like something bigger on tire size, im curious as to what spacer size i would need. from what ive searched people either use 10mm or 15mm, now im not looking for it to be perfectly flush as im dropped pretty low but i do plan to go back to stock sport springs sometime in the future, so im guessing i should be ok with a 10mm? any recommendations?
for OEM 166 wheels we usually do a 12mm in the rear, from offset ET28 to offset ET16. rear recommended tire size would be 275/30/19. no spacer really needed up in front as the front offset is ET12.
The_Sauce
06-26-2015 07:40 PM
madein
06-06-2015 11:48 AM
bestofthebest
03-30-2015 08:12 PM
