Rear tires or full set?
So I noticed the warning bars showing on my rear tires (275/30ZR19), 2008 550i with M package, which currently have Continental's on both front and rear. The front tires look to have a good bit of tread left before I get to the warning bars.
Would it be wise to replace all 4 tires at the same time or just go with the rears for now?
Thanks!
Thanks!
Thanks!
Thanks!
Thanks!
Thanks!
There was also a cost factor for me. Just my $0.02
For most drivers the only difference they'll feel is their wallets getting lighter by about $25! Nitrogen is used for certain tire applications where there is a wide variation in temperatures the tires will encounter [e.g Airplane tires] as it expands and contracts less than air.
Since car tires aren't usually exposed to these temperature variations ["real" race cars excluded] to the extent that inflation pressures would change dramatically this is another case where the marketing guys are hard at work figuring out ways to get into your wallets.
chadillac2000
42
Sep 13, 2017 11:15 AM
blackstarr
Feb 13, 2016 08:34 AM
