Picture request!
Delete
Why do you want a wheel that wide? Most owners don't go more than 9.5". In addition, tires that wide are not gonna perform well in Wyoming snow y'know. :huh:
Welcome to the forum, by the way :welcome:. |
I've used 275 width tires on 10-inch wide wheels on my other car but I think 11 will strech the tire sideways, unless you are looking for the stretched look.
I've also not gone with 19" as the tires alone are a lot more for a 19 than an 18" or 20". |
Originally Posted by jayarras
(Post 1556596)
Originally Posted by RIHI
(Post 1556622)
I've also not gone with 19" as the tires alone are a lot more for a 19 than an 18" or 20". Thanks guys |
Originally Posted by lowcg3
(Post 1556625)
You're right, I just figured since I'm going with 18" wheels I could probably get away with a wider wheel. Is there anybody on here running a similar setup? 18" wheels sitting low?
Once again, I hope you're just looking for summer, because you'll want a higher sidewall/narrow footprint tire for snow. |
(Post 1556628)
When you say "sitting low", I assume you mean a low-profile tire (i.e. skinny sidewall)? Or do you mean lowering the entire car?
Once again, I hope you're just looking for summer, because you'll want a higher sidewall/narrow footprint tire for snow. Thank you |
go with 19s
m5s have 19s and if u go with any wheel with a lip they are gonna look even smaller than stock 18s |
Op just so you know you can only run a 9" wide up front since you have KW co's. The offset would also need to be at least et10 so the inner wheel clears the spring perch.
