New Tire pressure recommendations for 2010 535i xDrive
My Ride: 535
Model Year: 2010
Just put in new Continental DWS tires.. the original Eagle RSA lasted 42K miles...
The door jamb says 33/36 I have original 17inch wheels .. 225/50/17 same tire wheel for all four.
The car feels a bit shifty compared to the previous tires.. I was wondering if I need to adjust to some higher tire pressure?? Any suggestions if you have the same car with same tires what tire pressure are you running. I have run only 50 miles so maybe I wait to put more miles on this tire etc.
THanks
THanks
My Ride: 535
Model Year: 2010
Continental website says this...
ExtremeContact DWS (225/50ZR17)
Product Name:
ExtremeContact DWS
Article Number:
15469960000
Tire Size:
225/50ZR17 94W
Approved Rim Widths:
6.0 - 8.0 inches
Tire Diameter:
25.90 in. (65.8 cm)
Tread Depth / Sidewall:
10" / BSW
Tire Weight:
21.30 lbs. (9.66 kg)
Tire Metric / Load Description:
Metric / SL (Standard Load)
Replacement Pressures (Front/Rear):
32 PSI / 35 PSI
Product Name:
ExtremeContact DWS
Article Number:
15469960000
Tire Size:
225/50ZR17 94W
6.0 - 8.0 inches
Tire Diameter:
25.90 in. (65.8 cm)
10" / BSW
Tire Weight:
32 PSI / 35 PSI
