New rims on my E60
Old Jun 6, 2013 | 07:35 AM
Ole Martin Fauske's Avatar
Default New rims on my E60
Hey, I'm looking to get some new rims for my E60. Today I have 245 /35 R19 on my front wheels and 275 / 30 R19 on my rear wheels. I have these rims now. http://finncdn.no/mmo/2013/4/vertica..._550313164.jpg
They are ET18. And the wheel hub on my car is 72,5.
The new rims are ET35 and the wheel hub on the sellers car is 74,1.
Will it fit or will i get some trouble?
The new rims im getting is http://www.gsbildeler.no/bilder/43167
They have the same tire dimensions as I have now. So the only thing different is the size of the rim.
Anyone knows if this would work or not?
Best regards
Old Jun 7, 2013 | 01:55 AM
BlaSTiWi's Avatar
In addition to what you think the only thing different is the size of the rim ... you will need at least a spacer ('cuz the offset is way different) and also a good hub ring ('cuz different center bore size) on the new set.
Old Jun 7, 2013 | 03:58 AM
Is there anyway to easily figure out how big spacers i need and how big hub rings i need?
Old Jun 7, 2013 | 09:19 AM
hub rings would be 74-72.5, and for spacers it will depend on the dimensions of your new wheels as well as the offset ET35 that you mentioned. here's the offset calculator many use 1010TIRES.COM - Wheel Offset Calculator for comparing 2 wheels, and the difference between them in offset would be the estimated size of spacer you would need to get the new wheels fitting like the prior set.
E60Japanese
Apr 15, 2015 11:38 PM
bestofthebest
Mar 30, 2015 08:12 PM
MartinF
Mar 27, 2015 05:52 PM
bananfiu
Mar 14, 2015 02:08 PM
ZeZe
Oct 15, 2003 12:58 PM
