LA forged wheel Radial Spoke 190 for 2010 550i M Sport
My Ride: 2010 550i M Sport
Want to get second set of OE 19" wheels for my 2010 550i
BMW LA forged wheel Radial Spoke 190
8 1/2JX19 ET:18
9 1/2JX19 ET:32
What do you guys can say about Radial Spoke 190 on 550i E60 ?
Any good ?
most of pictures I can google is for E90 ...
https://www.google.com/search?q=Radi...w=1280&bih=899
8 1/2JX19 ET:18
9 1/2JX19 ET:32
Any good ?
ok how about these ?
OE 20" wheels from 2013 F13 for my 2010 550 M SPort
My current wheels are
M double spoke 172
Tires Continental
Front axle 245/35R 93Y 81/2JX19 ET:18
Rear axle 275/30R19 96Y 91/2JX19 ET:32
replacement
20" LAW V Spoke 356
Tire Dunlop SP Sport Maxx DSST ROF
Front axle 245/35R20 95Y 8 1/2JX20 ET:33
Rear axle 275/30R20 97Y 9JX20 ET:44
will it work folks ?
Any problem with warranty ?
Any problem with Active steering / Speed Variance / handling i should expect ?
compare front
Stock Tire Size
275/30R19 IMPERIAL METRIC
Section Width: 10.83 in 275.00 mm
Rim Diameter: 19 in 482.6 mm
Rim Width Range: 9.5 - 11 in
Overall Diameter: 25.50 in 647.60 mm
Sidewall Height: 3.25 in 82.50 mm
Radius: 12.75 in 323.80 mm
Circumference: 80.10 in 2,034.50 mm
Revs per Mile: 815.81/mi
Actual Speed: 62.14 mph 100.00 kph
Speed Variance: -
Diameter Variance: -
Tire Size 1
275/30R20 IMPERIAL METRIC
Rim Diameter: 20 in 508 mm
Overall Diameter: 26.50 in 673.00 mm
Radius: 13.25 in 336.50 mm
Circumference: 83.24 in 2,114.29 mm
Revs per Mile: 785.02/mi
Actual Speed: 64.57 mph 103.92 kph
Speed Variance: 3.77% too fast.
Diameter Variance: 3.92%
rear
Stock Tire Size
Speed Variance: -
Tire Size 1
M double spoke 172
Tires Continental
replacement
20" LAW V Spoke 356
compare front
Stock Tire Size
Speed Variance: -
Tire Size 1
rear
Stock Tire Size
Speed Variance: -
Tire Size 1
mikes 5
Aug 19, 2015 06:12 PM
