Im buying rims, whats the correct offset to look for 545i Sprt Pkg.
My Ride: 05 545i Sportpackage, Mtech Body Kit
Im looking for new wheels, and i want to know what the correct offset should be on 19' staggered setup for a 2004 545i sportpackage. THANKS in advance
My Ride: Bmw 530d 2004
You can't go wrong when following the offsets of the OEM wheels, although you can go with more aggressive offsets too in many cases.
- Antti -
- Antti -
My Ride: 2008 BMW 550i Sport Carbon Metallic / Black
Traded in:
2005 BMW 545i Sport Black/Black
Traded in:
Factory specs for your car are:
Front: 18x8 +20mm
Rear: 18x9 +32mm
So to 100% match factory specs, get that wheel width/offset combo. But as posted above and in many other wheel/tire threads, you can deviate from those offsets to compensate for wider wheels, but may get into some rubbing issues depending on how far you push the offsets out.
Front: 18x8 +20mm
Rear: 18x9 +32mm
My Ride: 08 LCI 535i sport M5 umnitza full kit, Maya RM 1 245/35/20 20x9 et16, 275/30/20 20x10.5 et17, Future mods- KW coilovers V3 and StopTech brake
It all depends on how agressive you want to go. Most people on the forum run staggered. Everyones taste is subjective. I personally like staggered and very aggressive. I'm running an m5 set up with 20x9 et 16 and 20x 10.5 et17. Here's a cool calculator to figure out how much the rim lip will be flush
http://www.gtsparkplugs.com/WheelOffsetCalc.html
I don't think the wheel well or anything is any different on the 545 vs the 530.
I believe I have 19x9 ET 22 and 19x10 ET 14 on mine. I could proably go with ET24 on front to get the super flush but would probably rub. rear is max flush without rub
I'm sure you can find a pic in here somewhere.
So im looking at some new wheels, one is 19x8 et 20 19x9 et 25 and the other is 19.8.5 et 15 19x9.5 et 22
Which setup would be more flush with wheel well/aggressive>>?
My Ride: 2007 E60 530i
2007 E70 X5 3.0si
2001 E53 X5 3.0 (gone)
1997 E39 528i (gone)
First setup vs. OEM: Front: the same. Rear: sticks out 7mm more.
