Help with wheel offset
Good morning
So I have a 2006 525i I have found some own 18" rims to replace my 17" so I understand the "IS" number is the offset and the current wheel I have is 20 and the new IS is 50 will there be a problem with fitment? |
This link may give you some guidance. BMW 5 Series 2006 - Wheel & Tire Sizes, PCD, Offset and Rims specs - Wheel-Size.com.
Wheel offset is generally designated as "ET" and is generally stamped on the back of OEM rims as such. I'm not sure what "IS" refers to, unless that's what your wheel manufacturer calls it. As noted, the proper offset for your vehicle is ET 15, so if you have "20", I guess that works, but "50" definitely will not. |
5 Attachment(s)
The pictures attached are
my rim info the second is the ones im looking at and a picture the seller does not know what vehicle the rims came from |
The second rim is Style 135, which does come with a 50 offset in OEM, but is intended for the M3. It also comes in ET 20, which, if the IS # is any indication, this ain't it. My guess is that the IS 50 won't fit your 525i.
thank jayarras i appreciate it i found a good site as well with all the styles All BMW wheel styles | BmwStyleWheels.com
ok i have 18mm spacers also so technically i can get a wheel with an offset up to 38?
| All times are GMT -8. The time now is 04:51 AM. |
