Help with wheel offset
Old Sep 22, 2015 | 02:36 AM
Domrepkid's Avatar
My Ride: 2006 525i stick
Model Year: 525i
Default Help with wheel offset
Good morning
So I have a 2006 525i I have found some own 18" rims to replace my 17" so I understand the "IS" number is the offset and the current wheel I have is 20 and the new IS is 50 will there be a problem with fitment?
Old Sep 22, 2015 | 05:22 AM
JayArras's Avatar
Administrator
My Ride: 530xi
Engine: N52
This link may give you some guidance. BMW 5 Series 2006 - Wheel & Tire Sizes, PCD, Offset and Rims specs - Wheel-Size.com.
Wheel offset is generally designated as "ET" and is generally stamped on the back of OEM rims as such. I'm not sure what "IS" refers to, unless that's what your wheel manufacturer calls it. As noted, the proper offset for your vehicle is ET 15, so if you have "20", I guess that works, but "50" definitely will not.
Old Sep 22, 2015 | 07:59 AM
Domrepkid's Avatar
Model Year: 525i
The pictures attached are
my rim info the second is the ones im looking at and a picture the seller does not know what vehicle the rims came from
Attached Thumbnails Help with wheel offset-fullsizerender.jpg   Help with wheel offset-fullsizerender-2.jpg   Help with wheel offset-img_1485.jpg   Help with wheel offset-img_2976.jpeg
Old Sep 22, 2015 | 08:48 AM
JayArras's Avatar
Administrator
My Ride: 530xi
Engine: N52
The second rim is Style 135, which does come with a 50 offset in OEM, but is intended for the M3. It also comes in ET 20, which, if the IS # is any indication, this ain't it. My guess is that the IS 50 won't fit your 525i.
Old Sep 22, 2015 | 01:43 PM
Domrepkid's Avatar
Model Year: 525i
thank jayarras i appreciate it i found a good site as well with all the styles All BMW wheel styles | BmwStyleWheels.com
Old Sep 23, 2015 | 01:44 PM
Domrepkid's Avatar
Model Year: 525i
ok i have 18mm spacers also so technically i can get a wheel with an offset up to 38?
G530
May 15, 2015 10:42 AM
BurtonSnol3order
May 7, 2015 08:35 PM
asinner
May 6, 2015 06:03 PM
Kasmo
Apr 12, 2015 02:38 PM
Columbia1991
Mar 14, 2015 05:58 PM
