Help Offset?
![Exclamation](https://5series.net/forums/images/icons/icon4.gif)
Hi there guys, i've searched everywhere and wanted to know if someone out there could help me with some simple questions. im not a tire/wheel expert and would like to know if some wheels im interested in would fit my 2007 525i with 17in stock wheels.
the wheels that are for sale are:
19x8.5 (front), 19x9.5(rear)
5x120 bolt pattern
ET35 offsets all around
i herd that i might need spacers in the front? i have no idea and would appreciate some help.thanks![Bashwall](https://5series.net/forums/images/smilies/imported/bashwall.gif)
Also what would be the best tire fit for these wheels?
5x120 bolt pattern
That is a big/high offset number suitable for xi/AWD model (also on E90 3-Series) but for i/RWD model you will be using small/low offset number ET15-20 (around that not sure myself) ... so you can fit them but you'll need to use big spacer maybe +/- around 15-20mm.
youll need spacers for both front and rear. front Id put 20mm and rear Id put on 15mm. recommended tire sizes for those dimensions would be 245/35/19 and 275/30/19.
umnitza
09-02-2015 11:28 AM
