Help! Can original M5 166M 19" rims fit on a 530i?
Question as topic. I am not talking about Taiwan made replica 166M. I heard original OEM M5 166M got different offset and cannot be installed to a 530i but i have seen people in this forum did it.
So confused now |
So confused now Even if you were concerned about offset, there is nothing spacers can't fix. I may be replacing my replicas with OEMs. After I lower my car this weekend, I will be making a final decision. |
No problem at all, they go on without the slightest problem.
Only difference is that the M5 uses different tyre sizes. |
So confused now btw the replicas are also mostly made by Italian and other factories. Go with the 166 the best for oem :thumbsup: |
If you dont have a 530xi then the OEM M5 wheels along with theses tires
245/35/19 f 275/30/19 r Will be perfect. Will fit with no problems. If you want the rear to look better add a 10mm spacer. |
An even better look would be to add a 12mm spacer in the back. :thumbsup:
btw the replicas are also mostly made by Italian and other factories |
Originally Posted by olli_535d' post='337076' date='Sep 21 2006, 06:53 PM
good point. My M5 (166 style) replicas are made in Germany and I have never had the slightest problem with them. Perfect finish, no vibration, nothing.
Some are good, some not. |
Thanks for the info guys but i kept getting different answers.
I am not talking abt taiwan/italy or germany replica I am talking about geniune BMW M5 wheels to be fited on my 530i (not 530xi) Anyone did the same thing to his car please reply. many thanks |
