Guys, is this normal tire wear on a e60 rwd?
Old 08-16-2012 | 08:28 PM
djinferno1's Avatar
Does someone know why this would be happening? The shop told me that my suspension is fine but for some reason, my tires are worn allot more on the right rear then the left on the inside...
This is my second BMW, I bought them both used with no accident records but the 2 cars felt like they where leaning to the right side...
My mechanic tells me its normal because BMW cars because the car only pulls from the rear right, is this correct?
Why are my tires wearing allot on the inside?
is it an alignment issue?
Suspension broken?
Too much camber?
Or is it just the fact that the car does not have a locked diff?
This can't be normal right?
Attached Thumbnails Guys, is this normal tire wear on a e60 rwd?-gatineau-20120816-00162.jpg   Guys, is this normal tire wear on a e60 rwd?-gatineau-20120816-00163.jpg
Old 08-19-2012 | 02:48 PM
imagine's Avatar
My Ride: 2009 BMW 528i Space Gray | Premium Package | Sports Package | Navigation
Check your alignment and Check the tie rods and bushings
Old 08-20-2012 | 01:06 AM
Theo's Avatar
My Ride: 2004 E61 530D - Dynamic Drive - Active Front Steering Sport Seats - Voice Control - Head Up Display - Nav Pro - Bluetooth - Panoramic roof - Front/rear heated seats
This is not normal, these cars will eat your rear inner tires away but should do so more or less equally on both. Never seen a clear difference in many tire changes.
Old 08-22-2012 | 08:36 PM
djinferno1's Avatar
thank you, i will check both wen i receive new tires...
Old 08-28-2012 | 06:55 AM
bgreaves's Avatar
My Ride: 2008 535i
Check the bushing in the right rear, I have a feeling something is bad down there. If it were out of alignment, then I think you would see more gradual wear on the inside tread as well. If the shock was bad, then you would see more wear at the center of the tire itself. It kinda makes me wonder if the tire is rubbing something on the inside (in the well itself???)
Old 08-30-2012 | 05:57 PM
TU2TLE's Avatar
My Ride: Silver 550i: Orion V2 - LCI Tail Lights - VRM 710 (Powder Coated Matt Black) - Magnaflow Cat Back Exhaust - Painted Brake Calipers (Red) - Painted Rear MTEC Kit (Black) - Window Tint (Windshield 70% - All other Windows 55% - Smoked Side Markers
its your bushing
Awest91
09-17-2022 11:05 PM
kongse
07-17-2015 03:29 PM
lowcg3
03-26-2015 11:23 PM
ZeZe
10-15-2003 12:58 PM
08-12-2003 11:41 AM
Quick Reply: Guys, is this normal tire wear on a e60 rwd?
