Fitting Style 230s on 535xi
Im just wondering if anyone has them on their 535xi ?? i have a set just laying around and i think the offset is close enough where it could definitely work
19 x 8 et37 19 x 9 et39 not sure about the tire sizes though 245/40/19 square setup ? or 235/40 265/35 ?? |
E90 wheels/offsets are a good moderate upgrade for the x-drive E60s. I mounted some on mine and they fit much better than stock.
Tires you can go square or 225/255 or 245/275. I'm not sure much much % diff 235/265 are |
Plug your specs into willtheyfit.com and as long as the rolling circumference difference is less than 3% front to back, you're good to go. Those offsets will work well on your xi.
i test fitted them without the tires the other day and they do look great, much better than the oem 17s that are on there now. On the hunt for tires now :)
