Easy Off oven cleaner
My Ride: 528i
Model Year: 2010 528i e60
Engine: N52k
I've seen Easy Off oven cleaner do a great job on aluminum wheels where the brake dust on the front wheels is deep.
What is likely to happen when you try to clean your stock BMW wheels with Easy Off? Does anyone have experience with this chemical? Does it destroy the painted BMW wheel?
My Ride: 2005 545i, premium package, 6sp manual, cold package, navigation package.
Model Year: 2005
Engine: N62
I am not sure what the chemicals are in Easy off, but if they are caustic (which usually is the prime ingredient for removing fats and grease), then I would not recommend. Caustic attacks aluminum and removes the protective film built up on the surface of the aluminum. The aluminum will oxidize again and regain the protective surface, but will appear dull.
My Ride: 2008 535xi
Engine: n54
I had to use it to get the brake dust off my wheels that I didn't clean for a couple of months.. I finished it off with wheel wax after and didn't have a problem. I didn't leave it on very long because I was afraid it would eat it up. This is after I used regular wheel cleaner, soap, simple green, simple green bbq spray.. I was out of options and I didn't care since it was winter wheels
Model Year: 2005
Engine: N62
Were the winter wheels steel or aluminum. Caustic on steel doesn't cause damage like aluminum - after all ovens are galvanized steel.
My Ride: 2008 535xi
Engine: n54
Oh my winter wheels are the stock 17" aluminum.. I have some nice 19's for the summer
Essentially I sprayed it. Waited until i could start rubbing off that baked on brake dust, and rinsed the wheels with water right away and continued scrubbing.
