E61 fitment question
Hey guys just picked up a 535xiT. Have wanted one for years and finally pulled the trigger. I'm interested in a local set and wheels for sale. They are miro 111's 19x8.5+35 front and 19x9.5+22 rear. I'm going to run 245/35/19's all around. Will these fit ok?
Be careful with staggered setups on an AWD car. The combo of rim and tire have to have the same rolling circumference on all four drive wheels. A 3% deviation front-to-back is allowed.
The offsets on your car are in the ET 35 - 45 range. Although not quite as attractive as the Miro 111s, you could look at a Style 312 wheel as a substitute. BMW wheel style 312 | BmwStyleWheels.com |
Thank you for your response. I'm going to run a square sized tire set up. The staggered width and offset difference will not affect overall circumference. The stock width and stock offsets are laughable at best. Terribly sized for this car. I do not want stock sized width or offset. I want wider and a bit more aggressive fitment.
I guess my question should be, will I have any rubbing issues either on the inside or outside fender lips with these sizes? I will be running a 245/35/19 all around. |
Originally Posted by JNJ
(Post 1579701)
Originally Posted by OldSpool87
(Post 1579750)
I run 18x9 et 31 square with Conti DWS 255/40 with no issues. Front filled out nice and rears could come out anoth 10-12mm.
What suspension were you running? I want to run a 18x9.5 et 35 square set all around, but I'm worried about fitment in the front. |
My suspension is stock all around. |
Do you have any pictures of your setup? |
https://cimg4.ibsrv.net/gimg/5series...6f880b07a.jpeg
Driver front https://cimg8.ibsrv.net/gimg/5series...f99c6912b.jpeg Drivers front https://cimg9.ibsrv.net/gimg/5series...95e345918.jpeg Drivers front https://cimg1.ibsrv.net/gimg/5series...21d6156bf.jpeg Driver rear https://cimg3.ibsrv.net/gimg/5series...64dc537e0.jpeg Driver rear https://cimg2.ibsrv.net/gimg/5series...00eb6fa61.jpeg Driver rear |
Thank you very much. Looks great.
(Post 1579750)
