Another wheel fitment example
Old 09-05-2018, 07:40 AM
kd7iwp's Avatar
My Ride: 2009 535xi Touring 6MT, 2001 325i 5MT
Engine: N54, M54
Default Another wheel fitment example
I'm looking for a set of winter wheels and found some style 262's and wondering if they would fit my 535xi. Based on my current style 277's I don't think this should be a problem. I looked at willtheyfit.com and it seemed to be okay but since you guys are more experts at this than me, thought I would throw it your way.
Last edited by kd7iwp; 09-05-2018 at 09:10 AM. Reason: Accidentally linked to a porn site instead of a wheel site!
Old 09-05-2018, 08:49 AM
Administrator
JayArras's Avatar
My Ride: 530xi
Engine: N52
If the Style 262s are staggered, you may have a problem since the rolling circumference needs to be the same on all four corners on a AWD car. What tires are you planning to use?
Old 09-05-2018, 09:07 AM
kd7iwp's Avatar
Engine: N54, M54
Fair point, the seller says they aren't staggered but the online guide says they should be, if staggered I won't bother. They have Goodyear winter runflats on them that I will be most likely replacing with Michelin X-ice's at 205/50/17
Old 09-05-2018, 09:19 AM
Administrator
JayArras's Avatar
My Ride: 530xi
Engine: N52
Just a note of caution... a 205 tire may be too narrow for the weight of a 535 wagon. Check the load range of the tire. Generally, 225s are the narrowest you can go on an E60.
Old 09-05-2018, 09:26 AM
kd7iwp's Avatar
Engine: N54, M54
Thank you! Forgot to think about that.
Old 09-05-2018, 09:28 AM
kd7iwp's Avatar
Engine: N54, M54
Also found some Style 159's from a 335i with 225/45/17 winters on them that I'll look into. Load rating should be fine. Offset is 34 but I think that should be okay. They'll stick out a centimeter more than my current ones but think that should be okay.
mtler
01-03-2014 07:42 PM
MillerLite
12-06-2013 10:47 AM
Cosmin
Detailing Forum
04-18-2010 01:38 AM
JStraw
06-24-2006 05:25 AM
znod
12-13-2005 06:07 AM
Quick Reply: Another wheel fitment example
