e60 tyre losing air
Hi All,
my e60 loses tyre pressure and as much as 20 psi in 4 weeks if not topped up it only happens on front wheels and I have so far taken them more than 5 times to reseal the rim and it is ok for 2 weeks and starts all over again . garage told me my rims are fuc*** and it is rust that is causing air to scape. i can't see any rust inside or outside of it and each time the garage uses their wire brush ( electrical and cleans all around the inner of the rim ( both sides) but still do you think it is my rim? if so would you have refurbished the rims at cost of £80 each or just buy a new set of 4 sport rims ? |
just get new wheels
Agree.. not worth your time, might as well make it a good time to upgrade/change your look since the cost of 2 is enough to pay for a whole set. If you're looking for stock rims you could get a whole set for a couple hundred easy.
