5Series.net - Forums
-   Tires & Wheels (https://5series.net/forums/tires-wheels-52/)
-   -   E60- 19" Breyton Magic wheels setup- help needed (https://5series.net/forums/tires-wheels-52/e60-19-breyton-magic-wheels-setup-help-needed-145708/)
j003 Sep 22, 2016 06:21 AM
Hi
Apologies if I get anything wrong here, i am new so bear with :D
I have a set of wheels that were bought for me as a present for my BMW E60 from what i've been told, these have come off a E39 5 series
Has anyone got this set up on their E60 if so, what size spacer is needed? as the bore is a lot smaller on these wheels compared to the BBS M5 i have on at the moment I don't think i will get enough or any clearance without spacers.
Thanks in advance
Hyper_545i Sep 26, 2016 05:27 AM
The E39's have a CB of 74.1mm whereas the E60's have a CB of 72.56mm. I believe they sell hub ring adapters to compensate. All depends on whether you want to go that route. I'm sure some of the wheel experts on here can confirm. I have not done this nor can I confirm. Please use this advice only as a guide. You may want to research more on your own. Good Luck!
