Can you fit a 10" wide wheel in front?
Old 08-19-2012, 06:54 PM
itz MURDAH's Avatar
My Ride: 06' BMW 530xi
Looking to get a set of winter/ everyday wheels and don't want to go staggered this time .. wondering if its possible to run 10" wide wheels all around offset is around 38mm? I have oem m5 fenders in front so I'm thinking I could pull it off thanks for the help
Old 08-19-2012, 07:39 PM
crypto's Avatar
I'm no expert at this but that seems a little large. My rears are ET36 and 10" wide and that fits in real nice. The front... I couldn't see that working. I have ET35 up front with 8.5" wide and it sits real nice. To do this from my point of view .. you'd be 3mm different in offset but 38mm different in wheel size. I guess if the M5 fenders are like more than 30mm wider than the stock it could work.
Old 08-21-2012, 09:16 AM
LessIsMore's Avatar
My Ride: 2009 535i Sport
Model Year: 2009
Engine: N54
Are the M5 fenders even wider than other e60's?
Part of this depends on what size tires you want to run up front/back.
Getting the same-size wheels/tires may just end up being the worst of both worlds. My guess would be that the ideal wheel size for a same-size setup is going to be less than a 10", too. (unless you're going for the stretch-and-poke look, in which case I'm done here)
Staggered is where it's at, IMO.
Old 08-21-2012, 09:59 AM
luigi524td's Avatar
I think 10" wide wheels for a winter / everyday setup for an xi is overkill - especially since you are in NY running wide and the required low-low-profile tires over snow and ice + horrible roads is not something I'd favor.
Old 08-21-2012, 04:21 PM
itz MURDAH's Avatar
thanks for the input guys .. I guess I'll go staggered again lol
Kasmo
05-07-2019 03:30 AM
addy33
04-13-2015 04:40 AM
Nihilation
03-26-2015 09:18 PM
E60I
03-21-2015 06:24 PM
08-12-2003 11:41 AM
Quick Reply: Can you fit a 10" wide wheel in front?
