Can I fit style 95 wheels on a 528 xi ??
I really like the look on the style 95 wheel. I'm not worried about a little stretch on the tire just wanna make sure it's not gonna poke out too much. I'm buying a set of kw v3. Please help me out here guys.
Anybody know looking to buy them asap if they fit ??
Make sure you check the wheels' offset (ET). The xi wheels typically have a 43mm offset, but the RWD models typically have a 20mm offset.
Edit: I found the 7-Series style 95 wheels on realoem.com. They're 9 x 19 ET 24 and 10 x 19 ET 24. The E60 M5 came with 8-1/2 x 19 ET 12 (Front) and 9-1/2 x 19 ET 28 (rear) wheels. My gut feel is that you may well run into an offset spec problem. HTH, Jim / crewzer |
Originally Posted by crewzer
(Post 1472309)
Edit: I found the 7-Series style 95 wheels on realoem.com. They're 9 x 19 ET 24 and 10 x 19 ET 24. The E60 M5 came with 8-1/2 x 19 ET 12 (Front) and 9-1/2 x 19 ET 28 (rear) wheels. My gut feel is that you may well run into an offset spec problem. HTH, Jim / crewzer Kevin |
It might be worth taking a look at this discussion, but I believe the pictured car is a RWD wagon (not an xi):
https://5series.net/forums/e61-touri...ls-e61-125569/ HTH, Jim / crewzer |
