alignment specs for oem m5 wheels
Hi!
I have 2006 e60 sport with oem m5 wheels. My right rear tires are pretty worn out on the inside and only 8,000 miles on it. Alignment on rear camber is based on 18 wheel specs. Can someone recommend shop to adjust rear camber of rear wheel to offset the negativity of wheel without replacing the original rear camber of the car. I from bay area. Thanks a lot guys. |
