2004 525i normal model, wheel and rim fitment help!
Front 225/40R19
Rear 255/35R19
Can these wheel size fit on my 2004 525i?
Thank you for looking through my post! Any answer and recommendations are appreciated.
What you have given us is the tire size, not the wheel size. It would be helpful to know if they are BMW OEM, and if not, who makes those wheels and both the offset number and the hub bore size. You can often get that information from the numbers stamped on the back of the wheel. Are there any markings?
Hi sorry, these are oem Bmw wheels, style 792M. Front size are 8Jx19 ET27 and Rear is 8.5Jx19 ET90.
Front 225/40R19
Rear 255/35R19
Not according to Bimmerworld.
The staggered wheel offset specs for your car are ET 20 front and ET 32 rear. You may get by by using spacers, but I personally would rather use wheels that fit.
So we have fitted these in the two rears are fine. But one problem is the right front ones. It makes a thud noise after a spin I reckon but the left is still fine. Do you know why it is? We reckon it was the bolt fitting was wrong but have no idea. We’re trying to get it to a tyre shop tomorrow. Do you have any suggestions or idea why it is happening?
