19x11 ?
My Ride: myob
Hey everyone, I'm getting ready to pull the trigger on some wheels for my car, a 545i sport.
The problem is the wheels I like are only available in 19x11 et22 and 19x9.5 et20.
What tire size could I run to get away with keeping my stock suspension and prevent rubbing?, will 275/35 on 11" and 245/35 on 9.5" look extra stretched?.
Also if anyone as a similar set up and care to share some pics it will be deeply appreciated.
Thanks in advance.
Thanks in advance.
My Ride: 545 modded the F out
Sport suspension/ H&R Sport Springs / Not rolled
![Name: IMG_8793-2.jpg
Size: 65.5 KB](https://5series.net/forums/attachments/tires-wheels-52/160941d1501526320-19x11-img_8793-2.jpg)
![Name: IMG_8799.jpg
Size: 47.8 KB](https://5series.net/forums/attachments/tires-wheels-52/160942d1501526320-19x11-img_8799.jpg)
Ksport Coilovers/ Rolled/ Pulled and Stanced during alignment---Running 255 30 20 on 11' rear wheel & 225 30 20 on a front 9.5" wheel .
(and yes I did rub)
![Name: ant6-1.jpg
Size: 63.3 KB](https://5series.net/forums/attachments/tires-wheels-52/160943d1501526320-19x11-ant6-1.jpg)
![Name: ant10-1.jpg
Size: 46.0 KB](https://5series.net/forums/attachments/tires-wheels-52/160944d1501526320-19x11-ant10-1.jpg)
![Name: ant4-1.jpg
Size: 68.5 KB](https://5series.net/forums/attachments/tires-wheels-52/160945d1501526320-19x11-ant4-1.jpg)
![Name: ant2-1.jpg
Size: 54.9 KB](https://5series.net/forums/attachments/tires-wheels-52/160946d1501526320-19x11-ant2-1.jpg)
if you keep your ride at stock height you might be able to get away with that tire setup w/o rubbing….MIGHT. (but I highly doubt it since you've got a 545 with sport suspension). That probably already sits pretty low as it is so the tire setup you're considering will most definitely rub. You'll probably need to run some negative camber as well. It's not impossible, just kinda takes the fun out of driving. I ran this setup for about 2 years.
(and yes I did rub)
![Name: ant6-1.jpg
![Name: ant10-1.jpg
![Name: ant4-1.jpg
![Name: ant2-1.jpg
My Ride: myob
Thanks for the reply ^ your chariot is sick man!, Just found out the 11" wheels as an offset of 25 and not 22 as I mentioned above, not sure how much better this will be based on what you said above.
As for the front every 19" wheel that I like is 9.5", will running a 5-10mm spacer with the et20 up front take the wheel ways outside the fender? And where were your front tires making contact ( strut, front or rear fender liner, outer edge of fender ?
Thanks again.
Thanks again.
Virak1985
06-16-2015 12:24 AM
VarrsToen
05-23-2015 07:43 PM
ucsbwsr
39
04-28-2015 08:38 PM
