Steering wheel not returning to the center position
Since my post in the E61 section yielded nothing I thought maybe you E60 gents can shed some light on this;
On All my previous cars (not BMW's) when driving, the steering wheel returned to the center position after big or small steering movements.
On my 525D (non active steering) when I slightly turn the wheel (changing lanes on the motorway) the steering wheel doesn't fully return to the center position. So I have to put the steering wheel in te correct center position, otherwise the car would continue driving in a curved line.
Maybe this is due to the fact that it is a rear wheel drive car?
Do any of you notice the same with your car?
My Ride: E60 530d M-Sport
Suspension geometry ( Caster + toe ) would normaly influence the steering back to the central position, however I believe the E60 has an electric servo assisted motor for the steering IIRC ??? oso not sure if the same rules apply on that .............? certainly doesn't sound normal tho.
My Ride: 535dA M-Sport
Carbon Black
Nasca Black leather
AFS
Comfort Access
Moonroof
Active seat vent
Xenon
Navi Prof.
Night Vision
HUD
High Gloss Shadow Line
A FWD car does center the steering faster than a RWD car, but your steering should turn to center while driving.
Maybe check your allignment, it could be off. A BMW (being a RWD car) is quite sensitive for wrong allignment (especially with RFT's)!
My Ride: 520i SE, 04, 18" 245s, Sapphire Black, Cream leather.
I manged to rip 2 front RFTs to shreds due to camber issues on the rear.
That aside comparing FWD and RWD cars here on this subject is useless and not worth doing in any case
Probation Members
My Ride: S85 N54
I’m losing my mind with the same symptoms. 2008 535 with just under 50k miles, no active steering.
When's the last time it was aligned? 50,000 miles isn't much, but those bushings are likely to wear out about as fast due to age as miles. Of course, if you DO have worn bushings, an alignment won't fix it - for that you have to replace the worn parts and THEN get an alignment.
TexaZ3
05-06-2015 09:54 AM
