How will I know if my E60 is overheating????
Old 12-05-2003, 10:31 PM
amethyste_beemer
Guest
Posts: n/a
I saw in an earler post that the E60 instrument panel does not show engine temperature! Only fuel guage and consumption gauge!
Then how will i know when, and if, my beemer starts overheating?!!
I simple can't wait for white smoke to come up the hood while I get stuck on the streets with my E60!
Thanks!
Old 12-06-2003, 03:11 PM
Woodstock's Avatar
Acording to the owner's manual, a warning tone will sound
Old 06-28-2018, 08:12 PM
Jnelson1182's Avatar
My Ride: BMW 525I
There is also andigital temp gauge in the "secret" OBE2 menu that you unlock thru menu in instrument cluster, I believe it shows the outside temp & the temp of our coolant..
Old 06-29-2018, 07:19 AM
FormerE30Owner's Avatar
The tachometer has an indication of temperature (albeit without numbers). Notice the white bars on the tach just before the yellow/red engine speed (6500 rpm). Normal temperature is when about 3-4 bars (lines) are visible. As the temperature goes up the lines disappear.
Old 06-30-2018, 10:56 AM
My Ride: BMW 525I
so as long as I see 3-4 bars there then I'm not running too hot? I normally have 5-7 bars there but haven't drove it long enough for it to get warm since reading your post and learning that method of keeping an eye on the temp.
Old 06-30-2018, 07:13 PM
That is correct. Once warmed up, I almost always see 4 bars. On very hot days, at idle, I might see 3 bars. Even when it is -40 C, I never see 5-6 bars.
Old 07-01-2018, 08:06 AM
audiophool's Avatar
My Ride: 535xi
They took the bars away on LCI cars. Sad.
Old 07-01-2018, 08:23 AM
If only they had replaced them with a real temperature indicator.
Old 07-01-2018, 02:50 PM
audiophool's Avatar
My Ride: 535xi
iDrive rulez, gauges droolz. I'm going to get a BlueTooth OBD2 port and run Torque on my smartphone. Even the so-called temperature gauge on our E53 is dumbd down and buffered to only point to 12 o'clock unless it's on the cusp of blowing up.
Old 07-08-2018, 01:31 AM
My Ride: BMW 525I
so lately I have been seeing only two bars it doesn't go any lower than that but still I see you said 3 as your lowest so I'm wondering is having only the 2 bars mean I'm running hot? Granted I live in mid/nor cal & over last week or so it has been starting to get really hot here.
Quick Reply: How will I know if my E60 is overheating????
