Worth to fix or new engine?
My Ride: 535 3.0 200kw
Hello fellas.
So couple months ago my bmw 2005 e61 3.0 200kw stopped working and i have no idea if there is point to fix the engine or attempt to get engine from market?
So i was aware or at least thought my engine block cover gasket is either leaking or its broken, whenever i was accelerating hard it had a lot of pressure, each time when i accelerated hard it did break some weak coolant pipes and all coolant ran out (but driving normal it didnt break anything and coolant didnt run away either), mechanic always said its nothing about block cover gasket but i think it was. So i gave my car to next mechanic to diagnose whats wrong with it, he then calls me that its now fked up, he saw that turbo vacuum pipes were not even connected and once he did connect them, engine started rattling heavily while driving so he turned car off, after this he could not start a car again, like the engine spins but doesnt start. He did check the compression of cylinders and ill add them as picture.
mikael12
08-13-2022 11:56 AM
