Aux problem
Aux problem
hi
my 2009 e60 aux works for a short time then switched back to the cd even tho im using the aux has anyone had this and how to fix it as it driving me insane
thanx
thanx
Well that should be your stating point. Switch cable then check wiring and connector. It's a wired system so not much can be causing it
stevieT (03-07-2023)
All the way to the back of the iDrive connector. The wire should be good. I think if anything it's a connector or cable issue. Maybe the pins inside the plug wore out.
My Ride: 2006 530xi (One black & one grey) 2010 X5 535d 1974 BMW 3.0CS 2008 535i, 2009 335d, 2011 X5 35d, 2008 335i FBO
Had similar thing happen to a customer's car, it ended up being the mode button on the steering wheel was sticking and causing the source to change. Hope that helps.
