Post-LM2 Retrofit Angel Eye Problem
Old 06-19-2019, 12:48 PM
RetrofitGuru's Avatar
My Ride: BMW 530i N52
Default Post-LM2 Retrofit Angel Eye Problem
Retrofitted a 2010 LM2 into my PreLCI E60 since I have also retrofitted the updated CCC on LCI modules that permits welcome lights and DRLs in Settings. My problem is that when the low beams are on, the angel eyes are off. However, the Angel Eyes work as they are currently my DRLs. I am hoping to have Angel Eyes on with my low beam night time lights, but I'm not sure the root cause of this issue. Anyone else with a LM2 that has angel eyes "On" with the low beams "On" would be able to share a TRC file of their LM2 or advice along those lines, as I am sure this is a coding issue.
Old 06-25-2019, 06:09 AM
JeremyR's Avatar
My Ride: E60
I would recheck the wiring as well.
Are you still using PreLCI headlights?
Old 07-09-2019, 11:25 PM
Yes I am still using the PreLCI headlights with LCI tail lights. I just finished tinkering around with the LM coding on NCS but I wasn’t able to turn on my angel eyes. If there is someone else that retrofitted LM2 but kept PreLCI headlights and would share their FSW_PSW trc file of their Light Module 2 that would be super helpful
Old 10-16-2019, 11:05 AM
BeeMWe60's Avatar
My Ride: 535d
Hi, I'm having the same issue. AEs work fine as DRLs , but they don't work as position lights nor with low/high beams on.
Have you come to solution?
I already compared my TRC to a TRC of my mates LM and they're exactly the same
Pre LCI headlights with LCI tails
lopealle
03-14-2014 11:16 PM
Roy7
15
06-05-2012 12:18 PM
98PoleCat
04-17-2011 06:58 AM
VirtualRain
11-10-2008 04:53 PM
jules
08-31-2008 08:15 AM
Quick Reply: Post-LM2 Retrofit Angel Eye Problem
